vac clutch install ?
stout1
03-23-2006 12:29:15
I have the engine back together and was wondering how to align the clutch plate with the pilot bushing. I don't have a manual that shows how to do this. Do they make those plastic alignment shafts for this application or is there another way to do it? Thanks for the help.
Michael
1031D
03-23-2006 16:27:40
 Re: vac clutch install ? in reply to stout1, 03-23-2006 12:29:15
I just eyeball it and bolt the clutch together, then use the belt pulley to line up the splines.
Augie
03-23-2006 18:58:54
 Re: vac clutch install ? in reply to 1031D, 03-23-2006 16:27:40
Yep, eyeball it, then rotate the belt pulley or PTO shaft to get the splines lined up.
It's an easy one-man job.
stout1
03-24-2006 05:14:41
 Re: vac clutch install ? in reply to Augie, 03-23-2006 18:58:54
I understand the eyeballing it part but I don't see how rotating the PTO shaft will help line up the clutch plate and pilot bushing? I think I'll just make my own alignment tool if one isn't available.
Michael
Augie
03-24-2006 12:37:45
 Re: vac clutch install ? in reply to stout1, 03-24-2006 05:14:41
Input shaft to pilot bushing alignment will take care of itself. The spline in the clutch hub is where it will hang up. Turning the PTO brings the input shaft splines into position to engage the clutch hub.
