Case G430 Electrical Diagram
TBaum
03-22-2006 19:03:58
I have a 430, serial number 8200211 is stamped on dash plate, I think it was built in the early sixties. Looking for a wireing diagram that shows how the voltage regulator, starter, alternator, keyswitch, etc. wire together. Trying to rewire this tractor, but I am tired of banging my head on the wall, can anyone help! I think it has an alternator, but I am a beginner, and I honestly wouldn't know the difference.
leeinmass
03-23-2006 06:58:51
 Re: Case G430 Electrical Diagram in reply to TBaum, 03-22-2006 19:03:58
Is it diesel or gas? If you have a fax, I can send you the diagram.
TBaum
03-28-2006 19:05:31
 Re: Case G430 Electrical Diagram in reply to leeinmass, 03-23-2006 06:58:51
Guys,
Thank you very much for your help. It is running like a top.
Travis
TBaum
03-23-2006 17:28:41
Thanks for your help. It is a gas engine. If you could fax the drawing to me at 605-271-7001, Attn:Travis, that would be great.
Paul L
03-22-2006 20:34:48
when I posted that last reply didn't realize or register you had a G in front of the 430. I have just a 430 without the G, don't know how much of a difference that makes.
TBaum
03-23-2006 18:00:02
 Re: Case G430 Electrical Diagram in reply to Paul L, 03-22-2006 20:34:48
A magnet will stick to the alternator/generator, it also appears to be longer than a typical vehicle alternator. It has a gear drive on the front for the tach. It also has a tag on it labeled: Prestolite with a serial # CJT 7104 A71. The light switch only had 2 posts and it was wired in series with a fuse that was also mounted to the dash panel. Thanks for your help.
Paul L
03-22-2006 20:32:50
First off, the tractor was built in 1962. Even though I don't have a diagram, someone else correct me if I'm wrong, but a magnet sticks to a generator and won't stick to an altenator? Alternators ar elong and skinny. The original light switch I think must have had three prongs. I wired a new switch in, and then had to rewire a utility light onto the back, and the circuit bypassed the light when I did this. So, all together, don't know if that helped or confused you, but someone will correct me if I'm worng, which sometimes happens.
