VAI oil capacities and locations
horsesnmo
03-22-2006 06:51:37
We recently purchased a 51 VAI at an auction.
We have ordered manuals so we will actually know what we're doing but we would like a couple of answers now if possible.
What weight oil(s) do you use, how do you check and where do you put them?
The tractor runs and moves but won't move in the high gears and is really slow (to the point of almost not moving) after it warms up even in the lower gears.
Any help would be appreciated.
53 VAI Guy
03-28-2006 13:53:06
 Re: VAI oil capacities and locations in reply to horsesnmo, 03-22-2006 06:51:37
FYI, I have a '53 VAI. I recently noticed that oil was building up in the flywheel/clutch housing due to a minor seal leak (either the rear main on the engine or the clutch shaft going into the transmission). In an effort to insure that the clutch does not get oil soaked (and ruined) I now leave the flywheel cover loose when I am not using it. This prevents the oil build up in the housing. Just a suggestion. BEATS BREAKING THE TRACTOR IN HALF. Good luck.
Steve_Md
03-22-2006 09:44:29
It sounds to me that you might have a problem with the clutch slipping. Either out of adjustment or worn out.
C. Amick
03-22-2006 09:24:34
You should find a copy of a manual on-line at the web site listed below:
