J.I. Case 930 Comfort King (diesel), 1965 model.
Bob Read
11-03-1999 20:29:36
I am having trouble with the hydraulics. The two slave cylinder controls work well, and I get full pressure to the two external hydraulic cylinders. But the 3-point lift suddenly quit while plowing with the chisels. The plow simply lowered after being lifted for turning at a corner, and refused to lift again. It did this once before after the tractor had set still for several years. But, it had worked fine for a couple of years afterward. How do I get to the controls for the 3-point lift? Is it under the platform (beneath the seat) or do I go into the tractor from the rear, near the pressure pump? Could an o-ring have ruptured? Thanks.
