Caseomatic
Zenny
03-20-2006 12:19:45
HELP - we have a 810B Caseomatic - trying to find out ANYTHING about the tractor, year/hp, etc. Can't find it anywhere - stamp on frame is 810B s/n 8146970 but side of tractor says 800 caseomatic. Dealer here thinks it is a david brown. it has original paint YELLOW!
BLR
03-23-2006 22:12:25
 Re: Caseomatic in reply to Zenny, 03-20-2006 12:19:45
Don't forget that your tractor has a torque converter drive and not your typical dry clutch. Don't try to rev up the engine and slip the clutch or you'll likely have whiplash. Change gears at low throttle settings and use the throttle to pick up speed kind of like putting your car in drive and adding throttle rather than reving the engine in neutral and dropping the car into drive. The lever on the left side of the steering wheel engages a direct drive clutch pack and can be engaged once you have your load moving and disengaged when the pulling gets tough. It's a nice system, particularly for 1958, but got a bad rap mostly due to peoples inability to use it properly. There was also some seal problems with earlier units that contributed to the bad rap.
JGarner
03-20-2006 14:19:04
The 810B is not a David Brown, it is a JI Case pre CaseIH, obviously your dealer is a youngster.The 810 is 54 HP, 251 CID, 8 forward 2 reverse dual range transmission and weighs about 6,000 lbs.
Zenny
03-21-2006 13:21:02
 Re: Caseomatic in reply to JGarner, 03-20-2006 14:19:04
thanks for your reply J. So, is my tractor"s model a 810B or the 800 that is on the tin work. Iknow it is original paint and yes the deal is "a youngster" even in my mine! Thanks again
jim in calif
03-21-2006 13:48:44
 Re: Caseomatic in reply to Zenny, 03-21-2006 13:21:02
In 1958/59, all the Case 800�s: 801-B�s (row crop diesels); 810�s & 811-B�s all carried the number �800� on the cowl. The actual tractor model is found on the �Serial number plate�, this plate is located just aft of the right side cultivator light.
Zenny
03-21-2006 19:06:38
 Re: Caseomatic in reply to jim in calif, 03-21-2006 13:48:44
Thanks for the imput, any idea fellas what this tractor is worth?
