430 eagle hitch question
BC in NY
03-20-2006 06:10:14
I was told that I would need a plow made for the eagle hitch (14" 2 bottom) because any other plow would not work due to where the 3 point arm hook to the tractor. Can anyone give me some insight on this? It sure would be appreciated. Thanx, Bill
CK RICHARD
03-20-2006 16:44:14
 Re: 430 eagle hitch question in reply to BC in NY, 03-20-2006 06:10:14
2 bottom eagle hitch sold last week on ebay for 75 bucks
Bret4207
03-20-2006 10:53:19
Other make standards 3 point plows will hook up with some fiddling. They won"t lift quite right, and they won"t always trail straight without some more fiddling. Give it a try before you condem the Eagle hitch as unusable like so many other folks do. As with the Caseomatic transmission, it just takes some getting used to. They"re really a pretty good system.
c hess
03-20-2006 08:09:35
I retract my statment-apoligize. Iwas thinking about my 470 that had a standard 3 point hitch. Eagle hitch did not sway side to side an so Case had a plow that was for use on Eagle hitches. It had its own way of flexing around curves-also unhooked if you hit a stone. I believe it was amodel b. Saw 1 sell for 400dollars last week. Was a 3 bottom..
traceyb
03-20-2006 08:04:56
only cat.#1
c hess
03-20-2006 07:58:24
any 3pt plow should work.
