DC parts
Jim and bob
12-21-2005 08:05:04
New to the case program. My neighbor has a DC that runs but is in need of an overhaul soon. The Case/IH dealer here supposedly can't get any parts such as rings, mains, etc. We want to do a basic overhaul. Where do we start for parts. Don't know the extent of parts that will be needed until we tear it down, but don't want to tear it down until we find parts outlets. Any suggestions would be appreciated. Thanks.
Scott KY
12-21-2005 19:18:47
 Re: DC parts in reply to Jim and bob, 12-21-2005 08:05:04
You can get a complete engine gasket set as well as the orings for the sleeves from your Case IH dealer. Rings are available from tisco but you should check the pistons to see if they have been changed before you buy the rings. I ran into that situation a few weeks ago. Tisco was able to get me a set of rings from the measurements of the ring grooves on the pistons. If you find anything else you need post again. This is an excellent source for information.
wilson
12-21-2005 12:42:00
rings (if you go by size, and all measurments) are available fron napa Mains Take out shims Rods Take out shims unless completely wore out (recons are available) Gasket sets fel pro number 7365 either hesd or full set. Neither comes with pan gasket but you can install rings and adjust mains and rods without removing pan. Through side holes If you should pull sleeves or have any doubt about water in oil put in new o ringd available from don L 507 433 0073. What is serial number of your tractor and does it have eagle (3 Point) hitch ???
