case sc magneto
alvy
12-21-2005 03:17:17
Hey guys,
i think this is the best forum on the net. mostly ego free. anyway i have a 53 sc 6 volt with a fairbanks morse x4b9c mag. no spark. looks a little rusty inside so i will clean it up and adjust the points and try again. if that doesn't work, i'm thinking about the right angle delco idea does anyone have a model no. and proceedure for changing that out. then again, can't i get a rebuilt case mag for about 125 bucks. that seems pretty painless. advise me please.
Alvy
Glen in TX
12-23-2005 21:04:40
 Re: case sc magneto in reply to alvy, 12-21-2005 03:17:17
Nothing wrong with that FM X mag. X is the later model and still made new and parts are available. I have aftermarket coils, points, condensers & gaskets for them too. Email me if you need parts. Don't throw that mag away. New FM-X mags are now $600 !!
jal-SD
12-21-2005 06:54:26
Any right angle delco distributor should work. We've converted several DC's & SC's with them, even got one off of an Allis. Flat IH & delco distributors will work too, but are a little tight in the filter area. As long as the flange is the same, you are good to go. Its been a while since we did one, & if I remember right, the right angle distributors rotate the other way, so you have to set your plug wires accordingly. If you have converted your tractor to 12V, just get a 12V coil, points are the same. A good IH dealer should have all replacement parts on the shelf, as IH sold the delcos as after market to replace mags in the 50's. It was less expensive to convert to distributors than fix the mags in those days, I have two H's that I grew up on that have had this done to them. Wish I still had the mags that Dad threw into the junk pile. (My $0.02 worth. jal-SD)
