Shaving the head
RC2
12-20-2005 20:27:11
How much can i take off the head and what would be the com. ratio? Head number is #6386A and the engine number is #B4862A. And i supose it is stock! What RPM can this unit run before getting into trouble?
King Case
12-21-2005 03:51:44
 Re: Shaving the head in reply to RC2, 12-20-2005 20:27:11
Sounds like you have a LA LP head on this tractor. The comp ratio all depends on what bore and piston type you have. If you have for instance a set of 4 7/8 pistons which come flush with the top of the block you will not want to shave it. It will be around 12 to 1. Some pistons such as stock are around .200 below the the top deck and are much lower on comp. The head cc volume for a LP is 139cc. A high comp gas LA head is 266cc so there is a ton of diff in the heads. So the head you have will make a ton off comppresion with the right stuff. As far as rpms im turning around 2200 with my puller with a 7"" stroke. I turned a stock one about the same and never had any trouble. Hope this helps King Case
