HELP Timing injector pump 730
Al47
12-19-2005 18:19:27
Could someone explain how to time injector pump on 730 case. Mine will only run with ether.I believe it is timing. Al
Joe - Kansas City
09-17-2006 13:44:11
 My 430 is finally done... in reply to
Klyde
09-18-2006 04:28:22
 Re: Need new fenders/sheet metal for C in reply to R Wyler, 09-17-2006 16:09:21
I think John Saeli has a couple nos fuel tanks for the C's.
Al47
12-21-2005 16:19:08
 Re: HELP Timing injector pump 730 in reply to Al47, 12-19-2005 18:19:27
I want to thank you c hess,I retimed injector pump, bled the air,hit the starter and it purred like a kitten.this tractor hasn't ran right for many years.It has always misfired. It now runs smooth thanks for all your help Al
Al47
12-21-2005 16:18:18
c hess
12-20-2005 08:36:29
Remove front valve cover- turn engine until timing marks on crankshaft on front of engine are lined up atdc.-check valve push rods -both should be loose-if they are loose you are attop of compression stroke an can than set pump at proper timing. If push rods are tight you need to turn engine i complete turn . Than remove large cap on topan in front of inj pump an you should see two lines -i on pump an i on gear - turn crankshaft to 29degres btdc an they should both match -if not you will need to turn pump. Was pump removed since engine run? Doyou get white smoke when cranking engine? If fuel system was worked on are you sure all air has been removed?
Al47
12-20-2005 13:08:51
 Re: HELP Timing injector pump 730 in reply to c hess, 12-20-2005 08:36:29
Yes,the pump was removed.It does have white smoke.I would guess that means it is getting fuel
Al47
12-20-2005 13:08:04
c hess
12-20-2005 08:48:35
Should have said it is only nessary to remove an check valves if you are sure pump has been removed . If pump has not been removed you only have to make sure timing marks on front of crankshaft an timing marks inside cap are atproper setting . 29 degrees btdc
c hess
12-20-2005 08:54:08
 Re: HELP Timing injector pump 730 in reply to c hess, 12-20-2005 08:48:35
You may still have to turn engine i full turn even if pump has not been removed to be at spot you check timing.
