Clutch parts for Case 380 L L / D.B. 885
GrampaT
12-19-2005 15:56:11
I just talked with a local mechanic about the clutch assembly and he recommended replacing the entire assembly and the two clutch parts...an expensive venture it appears. Does anyone have a clutch assembly for sale? The spacer plate is ok. We may disassemble the unit and see if it can be repaired (I'm not holding my breath...just hoping). I haven't ordered any parts yet in hopes of finding an assembly a little cheaper and determining what comes as part of the assembly.
Jean Thibault Castagno
05-13-2006 15:49:11
 Re: Clutch parts for Case 380 L L / D.B. 885 in reply to GrampaT, 12-19-2005 15:56:11
And my father owned a Case Tractor see www.coventryct.org good grief, J
Glen in TX
12-20-2005 21:35:02
Since some things could be the same as a DB 885 you might also try Elmer in Canada, [email protected] He knows the David Browns well.
