Unidentified Case
Tim Behr
12-19-2005 15:32:44
This is a Case I acquired about 10 years ago. It had no ID plate on it at the time. It is in the garage now awaiting restoration, (minus the loader body), but I cannot find out what it is. I have looked at all the pictures I can , but nothing looks the same. This much I know (I think) 1941? (was told), 3 speed, 2 brake pedals on rt, FLAT front grill, not rounded like all the pictures I've seen, rounded off 'hood' edges, (unlike the L series), solid wheels, 6v negative ground, V groove fan pulley,(not flat), all of the casting numbers seem to end in "-A". Can anyone out there help? Thanks in advance.
Tim Behr
12-20-2005 14:25:20
 Re: Unidentified Case in reply to Tim Behr, 12-19-2005 15:32:44
OK , It's there. I never would have found it until I cleaned everything up. It says SI 5101850 so from what you are saying, its a 1947? I guess the guy I bought it from was wrong on the 1941, wasnt he? So you are saying its an "S" series, industrial version if I am correct on this. This will help tremendously in getting parts. Thanks again guys.
Tim Behr
12-20-2005 06:08:37
Many thanks, I will look for the casting number when I get home, The loader body is off now, so if you need clearer pictures without all the extras, I can post them. Thanks again.
Walt Davies
12-19-2005 17:14:31
Tom you sure that's not an SI, it looks just like the 43 SI that I had. Except my battery was not hung on by a rope giggle
Walt
dctom
12-19-2005 16:11:21
oops didnt look at whole picture sit is a "SI" industrial version of the "S" series tom
dctom
12-19-2005 16:09:11
that is a case "DI" industrial version of the"D" series, look on the engine flange right behind the air cleaner serial number should be stamped there, subtract 2 from the first two numbers for the year (ie 5200001 = 1948) tom
Joe (Wa)
12-19-2005 16:24:21
 Re: Unidentified Case in reply to dctom, 12-19-2005 16:09:11
Aaaaaugh Tom, You are the most knowledgeable Case tractor guy that has come down the pike in many a year, that's a given, but not even you can substract 2 from 52 and come up with 48. That takes a special talent that only us engineers possess.
First 2 digits minus 4 = model year.
Joe
dctom
12-20-2005 05:23:38
 Re: Unidentified Case in reply to Joe (Wa), 12-19-2005 16:24:21
ok so i made two mistakes and only caught one of them guess it is time i retire from all this and take a looooo oong break
Joe (Wa)
12-20-2005 09:44:32
 Re: Unidentified Case in reply to dctom, 12-20-2005 05:23:38
Ah Tom, I was just kidding you, the form would not be the same without you. If anyone needs to take a long break from YT, it is me.
Joe
Tim Behr
12-19-2005 15:35:41
Sorry, missed sending the pic, here it is...
third party image
