Governer Question
KP in PA
12-19-2005 15:15:42
Have a 51 VAC, my first project, runs ok if i don't use the hand throttle, using hand throttle, feels like the governer does work, i guess i have more control with foot throttle. I have time to get to tractor, and already have the radiator off...(Tarp accident) and pop and i are going to open it up, wondered if anyone had an "easy fix" or suggestions of what may be wrong
1031D
12-20-2005 19:41:11
 Re: Governer Question in reply to KP in PA, 12-19-2005 15:15:42
I had a 48 that ran goofy. I took it apart and found the floating pin/cup seperated. I welded it back together and welded up the groove in the arm, put in a new bearing, retreated everything, and it works great. You can still get the floating pin/cup thing new from CASE. The needle bearing on the "handlebar" shaft is a commom Torrington bearing.
Olddog
12-20-2005 03:49:51
Check the bushing in the front cover, where the "handlebar lookin'" governor lever comes out. A few thou. of wear here, translates into almost negating the "opening up travel" to the carb.
Augie
12-20-2005 09:57:22
 Re: Governer Question in reply to Olddog, 12-20-2005 03:49:51
What I found on mine was the follower paddle on the lower end was real sloppy on the "handlebar lookin" piece. Used a prick punch to tighten things up around the roll pin. Made a world of difference in throttle response.
Joe (Wa)
12-19-2005 16:59:06
There probably isn't anything with the governor, the plunger can get can sticky in the cam cavity and too a lesser extent the flyweights hinges from oil sludge. Other than that if the arms move freely the problem is likely external, binding linkage, wrong or poorly adjusted control spring.
The link is the mj's website featuring the VA service manual. Click on Group 2 Engine
For gov click on page G2 H2. Your model year is the flyweight gov.
Continue on in the engine chapter for throttle adjustment pages starting G2 S26
Joe
