Case VAC block repair ???
Sam F.
12-17-2005 20:35:50
I have a VAC that someone has patched the block behind the carb. The JB Weld is starting to flake around the edges. Can I grind the block in the crack into a V shape and then fill good with JB Weld again ?? Or any other suggestions ?? Does not leak into engine yet.
F-I-T
12-18-2005 16:47:19
 Re: Case VAC block repair ??? in reply to Sam F., 12-17-2005 20:35:50
I like muggyweld. Easier than brazing, more permanent than epoxy.
Frank
GeoMo
12-19-2005 05:52:58
 Re: Case VAC block repair ??? in reply to F-I-T, 12-18-2005 16:47:19
Have you welded overhead with muggyweld?
I have a crack in my 830 transmission housing.
F-I-T
12-20-2005 13:37:09
 Re: Case VAC block repair ??? in reply to GeoMo, 12-19-2005 05:52:58
Geo:
No, I have not. I have always made it a point to have the part on the table so I can use my rosebud torch for heat up and cool down.
You might e-mail them. The folks there were very helpful to me.
Frank
WeirdDeere
12-18-2005 03:17:23
You could JB weld it, or stick weld it with nickle rod. Or you could put some sort of sheetmetal patch over the crack. Our VAC has the crack in that location, my dad welded it, and no leaks since then.
Luckily, all the cracks I've seen are on the outside- so it shouldn't leak into the engine itself. It seems that nearly every VAC I've seen here in the freezing north has a busted block-right behind the carb!
Brandon
My Industrial John Deere website
John Deere Diesels
The LaGrange Engine Club
