SC belt pullly
Rockcricker
01-13-2006 18:40:56
I have a 48 SC and it hasn't ran since I got it. I just turned the engine over with the starter but not to start it yet and the pully turns when the engine is truning over. I drove one when I was a kid but don't remember that far back. Should it be turning or just when you push the clutch in? Thanks for any help.
C. Amick
01-16-2006 09:30:47
 Re: SC belt pullly in reply to Rockcricker, 01-13-2006 18:40:56
The clutch might be dragging a little. I would wait until you get it running to adjust the clutch. I had one that seemed too tight until I got it running and got the clutch plate oil coated.
Camboted
01-14-2006 00:44:08
Just when the clutch is engaged. Your clutch is stuck. Not uncommon for an old tractor that has sat along time, especially if the clutch was engaged.
Try opening the side cover and putting in enough kerosene to fill the cavity the slowly turn the engine over with a crank allowing all the surfaces to soak in the kerosene for at leat 10 minutes. This may free it up. Remember that this will flow into the crank case eventually as you run the tractor, so be sure to change the oil if it does start. You may also try putting the tractor in 4th gear and rock the rear wheels with the clutch dissengaged, after you add the kerosene.
LOL!
Rockcricker
01-14-2006 06:22:54
 Re: SC belt pullly in reply to Camboted, 01-14-2006 00:44:08
I guess I should of said that the clutch is new. I was wonder after I posted this if I need to adjust it? Thanks for the help.
Camboted
01-14-2006 15:24:47
 Re: SC belt pullly in reply to Rockcricker, 01-14-2006 06:22:54
That's your problem then. The clutch is set up too tight. If you didn't back off the adjustment, that is certainly what is wrong. You need to get a manual and re-adjust the clutch. This is done through the inspection cover on the left side of the tractor, not externally.
Rockcricker
01-14-2006 17:03:57
 Re: SC belt pullly in reply to Camboted, 01-14-2006 15:24:47
I have a manual. Don't have a tool. I did move the adjustment when I had it off. Not sure if I backed it off. Thought I did. Thanks for your help.
Paul Janke
01-14-2006 03:09:58
My SC is a 1941 so it might be different, but it has a wet clutch. It runs in oil. I don't know if they can get stuck. Maybe the newer one is a dry clutch. As to the original question, the pulley turns any time the engine turns while the clutch is engaged.
