? for dctom
52 DC
12-17-2005 10:04:26
tom, had a knock in 52 dc3.oil pressure is 40-45. drained oil and removed inspection covers from oil pan.found #3 rod to have metal shavings that are sticking out, around the rod&cap. there are shavings in the oil pan also.my question is.what are the shavings? shims or babbit material? thanks
52 DC
12-17-2005 10:36:45
 Re: ? for dctom in reply to 52 DC, 12-17-2005 10:04:26
thanks tom, it is silver. I called case dealer they said they can get new rod for 100.00.they need to know what size. i have no history on the engine. will have to take it out and mic it. thanks again.
dctom
12-17-2005 10:23:02
what color are the shavings?? yellow shims silver babbit take that one out(you can thru he bottom) check crank and put in good babbited rod if crank is round should be ok dont understand oil pressure with like that unless the hole to that rod is plugged tom
