head gasket leak
chiefrider
12-17-2005 02:08:41
Anyone know how to get a head gasket on a VC flathead to stop leaking.This is a new gasket.Head has beeen trued.Anything I can use on it to seal?
John Saeli
12-17-2005 05:39:44
 Re: head gasket leak in reply to chiefrider, 12-17-2005 02:08:41
Hey Chief: The Block may not be true, & may need "Decking". Never re-use a Head Gasket. Nuts must be Torqued to Spec's, using the correct patern, & last but not least, Re-Torque when warm. To Re-Torque, start with the 1st nut, back it off 90 degrees, & bring it back up to Torque. 1 at a time, do this with all of them, in the correct pattern. Good Luck
