VAC-pto
Sam#3
12-16-2005 19:29:45
third party image
I have a situation for which I am seeking advice.
I have a VAC that I finally made run and have the hydraulics working. My intent is to load it with 3 point rotary mower to use for cleaning corners and small spaces. As I was beginning to make up a top link I realized the link was going to interfere with the pto control level. See the photo if it came up.
Some research found that the entire pto was changed and the replacement rebuilt by the previous owner. Using the parts catalog and operators manual I have concluded the problem can be overcome by replacing the control lever and fork. I don�t want to change the entire assembly because of the rebuild.
My question is; Am I correct that this is my approach or have I missed something?
Thanks in advance.
Sam
Sam#3
12-17-2005 17:43:15
 Re: VAC-pto in reply to Sam#3, 12-16-2005 19:29:45
Thanks for all the input everybody. I think one of the ideas to either bend or cut and weld would be preferable to trying to find the parts and opening the case. I just want it to function not win a beauty contest.
Thanks again, Sam
Gary Cash
12-17-2005 13:57:09
I had the same problem when hooking-up my new post hole auger. I simply (or simple mindedly) bent the flat bar lever 90 degrees so it now points aft and clears my top link. It works fine.
mj
12-17-2005 12:55:27
third party image
Here's one on a '50 VAC
mj
12-17-2005 10:56:58
third party image
Joe (Wa)
12-16-2005 22:13:11
My engagement lever is less than 4" long. Looking at the back of the tractor, when disengaged the lever is pointing down about 5:30 o'clock and resting on a stop on the pto cover. The control rod attaches to the hole in the end of the lever and is vertical passing up through a bracket on the right side of the rock shaft. To engage, the control rod is pulled straight up and the lever rotates ccw and is fully engaged when the lever is pointing at about one o'clock.
In your pix it appears the control rod bracket is still mounted on the right side of your rock shaft. Your lever looks too long to be original and appears to be in the engaged position one detent too far ccw.
I will post a pix of the pto on my VAC if you want.
I also have a 311B with one of those slide on pto hydraulic pumps and a backhoe mounted on the eagle hitch and bracketed. The pto shift is nearly the same as the VAC and operated by moving the control rod straight up/down with the same lever engage/disengage attitude of the VAC. One time I apparently pulled it too far past the engaged detent and it disengaged and could not be forced back cw. I took the control rod off and pulled the lever ccw to about 9 o'clock and it is engaged, back to about 1230 o'clock and it is disengaged.
I have to pull the backhoe off to remove the pto cover and put it back in the original position someday but it's only been like that for 3 years, no sense getting in a rush with it.
Joe
Jerry W
12-17-2005 10:18:00
 Re: VAC-pto in reply to Joe (Wa), 12-16-2005 22:13:11
Joe
What you have is a 1949 and down style of engagement lever that original was pulled upward (engaged) with a rope. He has a 1950 and newer style of engagement arm that should have originally had a little bracket with a hole in it bolted somewhere to the chassis to hold the lever upright for easy accessability.
Jerry
Joe (Wa)
12-17-2005 11:32:35
 Re: VAC-pto in reply to Jerry W, 12-17-2005 10:18:00
Thanks, Jerry
I see that now but think it may be doable with the existing parts and changing the angle of the lever.
Joe
Sam#3
12-17-2005 05:38:26
Thanks for the input. I should have mentioned the pic. shows the pto in the disengaged position. It is turned to the CW direction to engage. I beleive, from my study of the parts manual, the lever and fork were changed @ #5450500 to operate as you discribe. I'm really trying to confirm that the parts can be inter-changed.
Joe (Wa)
12-17-2005 11:28:08
 Re: VAC-pto in reply to Sam#3, 12-17-2005 05:38:26
Yeah, I saw that but didn't spot that the shifter fork had been changed also.
If you were to change the shifter shaft 180 within the shifter fork it appears that it would not be fully engaged when the lever contacts the stop on the lower right side of the cover.
Might work if you rotate it and then weld another lever piece to the existing at an angle to have the control rod vertical up through the bracket on the rock shaft when fully disengaged and grind off the exposed part of the original lever.
The other option appears to be welding up the shifter fork roll pin hole and drilling another at a suitable angle. Probably not a good idea to weld directly on the shaft though.
Joe
Chris Brown
12-16-2005 20:01:52
Our old vac had a plate with a hole the shift rod went through ,the plate was bolted to the corner bolt that mounts the lift cylinder to the tractor. Just push ,pull the rod to shift.
