How replace fan belt Case 580B
old
12-16-2005 12:14:27
Friend has a 580B that he broke to fan belt on and I get the fun of replaceing it. How do you get in to the hyd pump drive to be able to remove it so you can put a new belt on??? Thanks
Roger (Mi)
12-16-2005 19:22:01
 Re: Replacing fan belt on a Case 580B in reply to old, 12-16-2005 12:14:27
Remove the right side panel. There are four bolts holding the coupler to the crank pulley. Remove the four bolts, slide the coupler toward the front. The fan belt can slide through. Also, the two bolts holding the hydraulic pump can be loosened to get additional space. Good luck.
