51' VAC Rear main bearing cap
WK-WA
12-13-2005 15:40:45
The rear main bearing cap is slotted on sides for a cotton rope type seal (A30483). The rope is about 20 inches long (1 for each side). Is there accepted method to install? I folded the rope in 3rds, twisted, and then tamping down with a punch. Or, should all the rope be used?
1031D
12-20-2005 19:31:33
 Re: 51' VAC Rear main bearing cap in reply to WK-WA, 12-13-2005 15:40:45
I did what you did by folding it in thirds. I soaked mine in slip-tac(#3) which made it a gooey mess, but it went in okay and seals nice and tight. I buy my slip-tac from CASE, it comes in a plastic can with a brush in the lid. The nice thing with slip-tac is it resists high temperatures and never hardens.
Tim Tenn.
12-14-2005 08:04:31
I have a 51 Ferguson with rope packing in my main cap also. After I re-built it, it leaked. I've read that the rope packing should be soaked in motor oil before installing.
Steve (Md)
12-14-2005 04:57:49
The concern for installing the rope is that you are sure not to have any voids in the rope channel when the installation is complete. The manual says to use a flat punch to install it.
Duner Wi
12-14-2005 05:46:20
 Re: 51' VAC Rear main bearing cap in reply to Steve (Md), 12-14-2005 04:57:49
I have not done a VAC but I have done that style of seal . What I do is use a 16d nail cut off sq. like a flat punch would be and I use butcher string and a little RTV sealer mixed in . Might not be a quick but it does seal.
