900 pto housing
Dave Sprague
12-11-2005 19:12:34
when I remove the rear housing off the back of the tractor and take the pto shaft out that runs to the front of the trans is there any gear or bearing up front of the trans that will have to come out also. Thanks in advance
Tom Railsback
12-11-2005 21:28:26
 Re: 900 pto housing in reply to Dave Sprague, 12-11-2005 19:12:34
Yes, there is. The shaft has a nut on the end which you reach through holes on the side of the clutch housing. Then you also have to remove the transmission cover to pull out the drive gear.
dctom
12-12-2005 05:15:29
 Re: 900 pto housing in reply to Tom Railsback, 12-11-2005 21:28:26
Tommy, are you sure about that?? this is not a DC and i beleive the live power on the 900 would just slide out tom
Tom Railsback
12-12-2005 06:34:49
 Re: 900 pto housing in reply to dctom, 12-12-2005 05:15:29
I was basing my reply on the picture in the 900 parts book, but what you say makes sense.
Dave Sprague
12-12-2005 07:29:26
 Re: 900 pto housing in reply to Tom Railsback, 12-12-2005 06:34:49
Thanks for your input guys
Dave
