Case 580B Transmission shift problem
Bob Augustyn
12-11-2005 07:41:25
I have recently purchased a 1974 Case 580B two wheel drive and found that third and fourth gears and drive train work fine. I cannot get it into first and second at all. The shift lever will not budge out of the neutral position in the first/second gear area. Third/fourth goes in no problem... Is this a common or major problem? Is there known problems with the shift linkage??
Is this a major costly/difficult thing to fix??
Roger (Mi)
12-12-2005 04:30:42
 Re: Case 580B Transmission shift cover in reply to Bob Augustyn, 12-11-2005 07:41:25
The problem is likely in the transmission shift cover. There are balls/pins that move in passageways in the cover to prevent shifting into two different gears at the same time. Put the transmission into neutral, remove the transmission cover, and check the movements of the interlock balls/pins.
