case 580ck backhoe w/ shuttle
John Suchocki
12-09-2005 14:31:15
just found what I think is hydralic oil in my radiator. After using for a while and parked the oil was dripping out of my over flow tube from the radiator. Anyone have this problem, leak in my radiator cooler? can they be fixed? Thanks, John
Roger (Mi)
12-12-2005 04:45:50
 Re: Oil in radiator in reply to John Suchocki, 12-09-2005 14:31:15
There are only two ways oil can be getting into the radiator. 1) If you have an oil cooler in the radiator, it could be leaking internally to antifreeze. (repair or replace the oil cooler) 2) The head gasket has an oil passage going through it to lubicate the rocker arms. Sometimes the head gasket leaks and allows that oil to find its way into the water jacket. (replace the head gasket)
