Case 580CK Hydraulic Pump Location ??
c0
12-09-2005 13:58:21
Does anyone know where the pump is located on the 580CK's. It makes a huge amount of what I am assuming to be cavatation noise, will a fluid change stop this, or does the pump need replacement?
Also, I already know that I have to change out all of the filters that have been placed in various places on the tracor, is there a way that I can bypass the multiple filters and switch to one large filter?
John Suchocki
12-10-2005 13:30:24
 Re: Case 580CK Hydraulic Pump Location ?? in reply to c0, 12-09-2005 13:58:21
had the same problem with cavitation noise in the front pump. Turned out to be the suction hose collapsing during a draw down for a cylinder. check your rubber hose between your reservoir and pump and see if you have a kink or if you can squeeze it. It should be solid and round. John
John Suchocki
12-10-2005 13:30:14
c0
12-10-2005 22:11:47
 Re: Case 580CK Hydraulic Pump Location ?? in reply to John Suchocki, 12-10-2005 13:30:14
Thanks for the info!!
Now I have a much better idea of a direction to point myself ;-)
jdemaris
12-09-2005 17:18:29
The pump is in front of the tractor, in front of the radiator. Running one filter won't work because there are several separate systems. The torque-converter system is totally separate from the loader/hoe hydraulic system.
c0
12-10-2005 22:13:16
 Re: Case 580CK Hydraulic Pump Location ?? in reply to jdemaris, 12-09-2005 17:18:29
Thanks for the information, so much for a simple solution ;-)
Looks like I am off to the Case / IH dealer for filters..
