David Brown 770
Karl Hamson
12-07-2005 14:57:32
Hi I was wondering if anyone in the Pacific Northwest or southern BC would be interested in a pretty sad 770. Perkins diesel and trans/driveline seem fine. Tin is either missing or horrible. Rear rubber so-so, car tires on front. Steering box pretty much shot. I guess I should be posting in the classified section but I thought I might find on this site if there are any interested forum members. I need the shed space for my Farmalls and don't want to shove the DB out into the rain.
Thanks.
Tim Pennell
12-08-2005 07:57:01
 Re: David Brown 770 in reply to Karl Hamson, 12-07-2005 14:57:32
I may be interested, just gotta see if anything matches up with my 880. I am thinking the back half of yours and the front half of mine. Do the hydraulics/3 point work?
Tim
Karl Hamson
12-08-2005 08:04:17
 Re: David Brown 770 in reply to Tim Pennell, 12-08-2005 07:57:01
Hi Tim I think the 880 is a much bigger tractor. The 770 is about the size of a MF35. 3 cyl diesel, power steering, 3 speed trans with 4 ranges giving 12 forwards and 4 reverse. Frankly the 3 point setup is so complicated I could not tell you if it works properly or not. It does go up and down and will hold a load for hours if everything is set right. Where are you located?
Tim Pennell
12-08-2005 08:08:52
 Re: David Brown 770 in reply to Karl Hamson, 12-08-2005 08:04:17
Hi Karl,
I am in Williams Lake, BC
The gears you describe etc sound the same as mine except different model as I only have two ranges. All I would use the 3 point for is mounting my backhoe, but if it goes up and down and holds that means the hydraulics work :o) Gonna call a friend at the dealer here and check. Where abouts are you located? Email me at [email protected]
Thanks
Tim
Tim Pennell
12-08-2005 08:20:11
 Re: David Brown 770 in reply to Tim Pennell, 12-08-2005 08:08:52
I just spoke to my dealer friend and they are pretty sure it will work, email me your phone number, location etc.
[email protected]
Thanks
Tim
