extracting metal from a field
sherry olson
12-07-2005 14:38:54
Is there any type of device that I can pull behind a tractor that will help get pieces of metal out of a field?
Paul f
12-08-2005 12:09:54
 Re: extracting metal from a field in reply to sherry olson, 12-07-2005 14:38:54
Gemplers and Northern (and other sell big magnets that are use to pick up nails etc from roads and parking lots. If you run a york rake or harrow over your field and follow with one of these magnets you should get a start...Unlikely any thing will get all the metal the first few times. (How big are the chunks you are trying to retrieve???
Doug Boll
12-08-2005 11:39:52
Buy a brand new set of tractor tires, you'll find it!!
Walt Davies
12-07-2005 17:17:22
Call a Rental place and see if they have a Tractor rigged with a magnet for picking up metal. These things can pull a bolt from 4 or 5 inches down in hard dirt.
Mikey
12-07-2005 20:01:00
 Re: extracting metal from a field in reply to Walt Davies, 12-07-2005 17:17:22
WOW!!! Don't wear a belt buckel!
boston bean potty
12-07-2005 16:02:44
the easiset and cheapest is to get a sheet of plywood and a short chain. hook it to the tractor. put your wife on the ply wood with a decent pair of cheap gloves and pull her around the field.she can lay on her belly and grab the junk when you tell her . to get ready and get to grabbing.dont use expensive gloves .. they will get ruined
Case1950
12-07-2005 18:03:41
 Re: extracting metal from a field in reply to boston bean potty, 12-07-2005 16:02:44
Now that is funny.
Gene Dotson
12-07-2005 15:00:46
Depends on what size and type metal you are referring to. I have used a field cultivator since I bought my farm. After I plowed it, I went over it with a field cultivator and have found chains, a starter, a generator and various auto body parts. The cultivator will leave them on the surface, but you still have to pick them up by hand. This also works well for leaving the rocks on the surface to pick up... Gene
Casenut
12-08-2005 17:06:02
 Re: extracting metal from a field in reply to Gene Dotson, 12-07-2005 15:00:46
Sounds to me like the field refered to was recently worked by somthing other than a Case. I am told that is why they were painted green and yellow. So they blended into the dandilions very well.
