VAC hydraulic pump
JeffL-TN
12-07-2005 13:20:28
Is there a repair/overhaul kit available for the hydraulic pump thats behind the belt pulley? I have one lat leaks bad from around the shaft for the belt pulley. I checked on this board and don't find anything. Haven't checked the dealer yet.
Thanks in advance.
Dale O
12-08-2005 13:38:56
 Re: VAC High press. hydraulic pump in reply to JeffL-TN, 12-07-2005 13:20:28
I would appreciate this info as well as mine leaks like a seive.
Thanks
kirk/ihcollector
12-08-2005 10:44:55
 Re: VAC hydraulic pump in reply to JeffL-TN, 12-07-2005 13:20:28
Jeff, I have the oil seal list on my computer. If you e-mail me directly at ( [email protected] )
I will be happy to email you the list.
MikefromIowa
12-07-2005 13:36:20
Jeff, I assume you are talking about the shaft that runs thru the pump assembly and powers the belt pulley. You can replace that seal. I have replaced mine. I just took it out and got one from NAPA. THere is a seal replacement guide here somewhere I just don"t have it book marked. I"m sure someone here does or do a search for seals.
