Need engine info
DaveFox
12-06-2005 16:37:35
I have a 1967 580CK. I am rebuilding the deisel engine. Can't find any numbers to tell what size it is. How can i tell if it is a 188 or 207.
I am taking the head off and have all the head bolts off and the 3 from the water pump to the head but it still seems stuck to the water pump. Any info would help. Does a regular case manual have a engine diagram?
Old Rusty
12-06-2005 16:58:31
 Re: Need engine info in reply to DaveFox, 12-06-2005 16:37:35
It should be a 188. If it has never had the head off before you will have to remove the water pump as there is a hollow bolt behind the water pump into the head. After you remove it the head will come off. There is no need to replace this bolt.
DaveFox
12-07-2005 17:21:29
 Re: Need engine info in reply to Old Rusty, 12-06-2005 16:58:31
thanks, I'll remove the pump and try that.
