Cam, good/bad?
bobV
12-06-2005 11:03:06
I'm at the stage to start rebuilding the engine on my 411B. everything will be new such as the sleeves,pistons,bearings,... but I'm not sure about the cam, because the tractor just ran when I picked it up that was because of broken rings,small hole in piston,bad valve. My question is,is there a way to check the cam?, measure each lobe?, otherwise should I replace it just for the comfort of knowing it is new, and if so who has that type cam. I read this comment section everyday Thank you all for your knowledge and responses in advance! BobV
old
12-06-2005 11:30:42
 Re: Cam, good/bad? in reply to bobV, 12-06-2005 11:03:06
It can be checked by a good machine shop. Also Case/IH should have new or redone cams, or value bilt may also have them
