DC valves
Scott KY
12-06-2005 04:38:10
What is the difference in the intake and exhaust valves for a DC? They look the same. I have a set of eight. Four are marked 794R Eaton, and four are marked PWR V 773. Can anyone tell by these numbers which are intake and which are exhaust?
DKase
12-06-2005 19:38:54
 Re: DC valves in reply to Scott KY, 12-06-2005 04:38:10
The old intake valves are much softer than the exhaust valves. They measure the same so they are interchangeable. All they make now are the hard exhaust valves. Do NOT put the older softer intakes in as exhausts or you will have trouble. I cannot tell you which is which by the part numbers. Bruce Nelson might be able to. Good Luck DK
L.Lamp
12-06-2005 10:44:49
DC valves from Case-IH are interchangeable. I would guess other manufactures would also interchange. The propane head has different size intake and exhaust and the stems are different length from the other heads.
