DB 990 selectamatic 3pth hydraulics
Jack-Ont
12-05-2005 11:11:11
As there is a trmendous amount of knowledge and expereince here, I hope someone can point me in the right direction. Yesterday I was using my 990 selectamatic to auger some post holes,for a new shed. Everything was going along swimmingly, I actually thought/hoped I would finish up earlier than expected, as it was quite cold and the snow was blowing in blizzard fashion. Anyway, as I said everthing was going well until I got to the 9th of 12 holes and all of a sudden the lift arms wouldn't come up. Strangely the front loader still has alot of power, so it can't be the pump. Even when I removed the auger the arms won't come up, any suggestions? As repairs will have to be done outdoors in this ice bound hell called Ontario in December, I really am hoping to find an easy/quick fix, as if that is likely lol. Thank you in advance. Email: [email protected]
Jack-Ont
12-15-2005 16:02:49
 Thanks everyone! in reply to Jack-Ont, 12-05-2005 11:11:11
Hi everyone, I just wanted to say thanks for the valuable advice. The problem was in the valve chest, the right valve was frozen in. I replaced oil and filter, and freed the valve so it's back to work. yee haw! Email: [email protected]
Elmer
12-06-2005 17:54:09
 Re: DB 990 selectamatic 3pth hydraulics in reply to Jack-Ont, 12-05-2005 11:11:11
Jack give me a call at 519 363 2663. I'll be in the shop tomorrow from 9Am on.
Jack-Ont
12-06-2005 18:25:06
 Re: DB 990 selectamatic 3pth hydraulics in reply to Elmer, 12-06-2005 17:54:09
Thanks Elmer, I'll call you tomorrow.
Jack
RPoff
12-06-2005 10:44:42
Elmer is the expert, also Barry Key. Just my guess, if you have pump supplied pressure on the loader is maybe the system needs bled or cleaned between the 3pt ram and the pump. All your linkage is good, yes?
Jack-Ont
12-06-2005 17:54:15
 Re: DB 990 selectamatic 3pth hydraulics in reply to RPoff, 12-06-2005 10:44:42
Hi thanks for the tip, I'm afraid I don't know how to bleed the system, any info on that would be greatly appreciated. the linkage all appears to be good, however, is it possible that this could be related to the sensing cable? I seem to think that the auger bit down really quick and sudden, maybe this tripped something?
Don't know how to get this post to Elmer's attention, is it possible to contact him through the site?
Jack-Ont
12-05-2005 19:02:26
 Re: DB 990 s 3pth hydraulics Elmer Help! in reply to Jack-Ont, 12-05-2005 11:11:11
Wilson, thanks for the info. Hopefully elmer will read this.
wilson
12-05-2005 14:34:36
post for elmer he is the db expert and is also from your part of the frozen north
