Water in oil and oil in water ?
JW
12-04-2005 16:40:44
I just pulled the heads on a nieghbors 930 dsl and in the process found that there was oil in the water and water in the oil. Water in the oil I can see but what would cause oil in the water? There is also a white crusty glaze on top of some of the pistons and stuck to a few valve faces. I pulled the heads because the front head gasket was leaking oil. He also tells me that it runs around 200 degrees just sitting and idling. Anyone have any guesses? This is the first one I've dealt with that had any of these problems.
Gene Dotson
12-04-2005 18:30:42
 Re: Water in oil and oil in water ? in reply to JW, 12-04-2005 16:40:44
Sounds like you have a head gasket leaking between the oil and water passages. I would recommend you pull all 3 heads and give it a through check. Make certain the head and block surfaces are perfectly clean, especially around the studs. Each head gasket has an o-ring that has to be installed in the rocker arm oil passage to prevent oil from leaking there.
Leaking o-rings on the sleeves would let water into the oil, but not oil in the radiator.
The temperature of 200 degrees sounds about right as long as it stays there when working. It should have a 195 degree thermostat... Gene
old
12-04-2005 18:24:01
May guess would be a blown head gasket which will cause both or either problem.
