Case 15-27 magneto?
Brian Rowe
12-03-2005 06:22:06
I have recently acquired what we believe is a 1921 Case 15-27 that has neither the mag or carb. I believe the needed pieces are a Kingston L2 for the carb and a Robert Bosch FU4 for the mag. Is this correct. Also is there any way to properly identify the serial number of this tractor? The number plate was removed years ago. Thanks in advance for any help.
Brian
Andrew from Aust
12-08-2005 19:37:14
 Re: Case 15-27 magneto? in reply to Brian Rowe, 12-03-2005 06:22:06
Hello,
Not sure whether someone may have helped you by now but the carb and mag sound right. Just from what i've seen in books!
I think the serial number might be stamped on the chassis casting underneath the water pump area.
I'm still learning too! I have 1926 12-20 & 1925 18-32 and they have numbers there as well. No numbers on the engine!
