Weak Case S
minnimolineman
12-02-2005 08:41:59
I've got a Case S that cannot move itself up the slightest incline even in 1st gear. It starts & runs good but when I let the hand clutch out it moves a few feet while the revs drop and just dies. Acts like the engine has no power. As far as I can tell the brakes are not locked up. Could I have some kind of problem with the govenor? It will run all day siting still in neutral and will run at different throttle settings (fast/slow/medium). It just seems too weak to move itself. Checking compression this weekend when I get back to it. Could it be anything else.
Camboted
12-02-2005 16:03:03
 Re: Weak Case S in reply to minnimolineman, 12-02-2005 08:41:59
My guess is that 'old' had it right when he said, "Timing". The thing is, if you have a magneto, most guys see the rotation of the drive and put the plug wires on accordingly, not realizing that the mag runs counter-cyclical, so 1&2 cylinders fire normally and 3&4 are fireing at the top of the exhaust stroke, it even sounds somewhat normal, but no power. Try switching the #3&4 plug wires and see what happens. 1 is nearest the radiator.
Jim Yadon
12-02-2005 14:44:22
I have a couple of questions. Are you located in the northern part of the US? Have you checked the rearend fluid for water? Sometimes there is enough water or moisture in rear end that is mixed with the oil which causes drag just like brakes. I have also seen rearends that have so much water in them and frozen solid you can't even get the rear wheels to spin while out of gear. This is the time of year especially if it is as cold as it is here in northern Indiana. Don't know if the will help but it is just another thought of what it could be. Good Luck
minnimolineman
12-02-2005 14:52:29
 Re: Weak Case S in reply to Jim Yadon, 12-02-2005 14:44:22
Jim--No Im in the south. Tractor rolls around ok in neutral so it does not appear to be brake or axle related but something that happens when I engage the clutch and ask the engine to move tractor. It's either got zip for rings or something with the govenor. I think I will try the transmission treatment and the govenor loading tests as suggested. Thanks for the tip though, I did drain about 3-4 gallons of water out of the rear end of a Farmall M I once bought.
L.Lamp
12-02-2005 11:01:08
It sounds like a lack of fuel to me, but check to see if the governor is working. Assuming the brakes are good,lock both brakes tight and put in 4th gear,set the throttle about 1/3 open and slowly engage the clutch till the engine comes under load without killing it. You should see the governor arm at the right front of the engine move as soon as more power is needed. If it doesn't respond, find a replacement governor unit. If the governor arm does move, the carburetor may be your problem. At the same throttle setting,turn the little tee fitting at the bottom of the carburetor counter clockwise until you have black smoke just visible coming out the exhaust and then turn it back in till you no longer see any. Make sure the choke is completely off. At this setting it will handle all but the most demanding loads very well. Repeat the test. It should not miss fire, if it does,you may have an ignition problem. Plugs, points,weak spark,timing. If no change in power, or no black smoke, you may need to rebuild the carburetor. If the engine is in poor shape it will smoke heavily out the breather pipe on top of the valve cover. If it hasn't been run in a long time,it MAY get better with use. An engine service manual would be a good investment and would help you make the necessary adjustments correctly. LOL
old
12-02-2005 10:02:52
You could have any number of things wrong. Timing might be off, carb set wrong or very low compression. Has it ever sat for say a year or more?? If so then you may have stuck rings and or valves. If your compression is low I'd fill the cylinders with tranny fluid and let it sit a couple days and then spin it over with the plugs out and see if its runs any stronger. One other thing you could have the fireing order wrong and that would also cause you problems.
minnimolineman
12-02-2005 12:31:11
 Re: Weak Case S in reply to old, 12-02-2005 10:02:52
Thanks for the suggestions guys. I'll give it a look over this weekend====
canuck_case
12-04-2005 13:57:16
 Re: Weak Case S - My 38 L has the same problem in reply to minnimolineman, 12-02-2005 12:31:11
I have the exact same problem with my 38 L that I just got running. So I look forward to your update. (My tractor is stored too far away to run out and check right away, and its winter here now)
I have rebuilt the carb, but tractor only runs with carb choked, indicating probably fuel related)
