DC radiator
Scott KY
11-30-2005 18:21:22
I dismantled the radiator on a DC I recently bought. The top and bottom cast iron tanks are very rusty inside. Is there anything I can coat them with to prevent rusting once I get them cleaned up?
Camboted
11-30-2005 19:34:29
 Re: DC radiator in reply to Scott KY, 11-30-2005 18:21:22
The important thing is to rod out the core. You will probably find most of the flues plugged. I don't know about coating, but you can treat the rust with a phosphate based product that will turn the rust black, basically de-oxidize it. Then there are good rust inhibiting additives and anti-freeze products you can use. The difficulty is that your block probably looks like the tank, so chunks of rust will occasionally break off and plug your clean core. The best idea I heard of is to hang a bar magnet in the tank. LOL
