VAC oil pump
stout1
11-30-2005 14:11:40
I've been having a hard time finding an oil pump for this engine. Is anyone else having the same issue? I took the cover off and it looks like you can just replace the gears in it. I am going to look and see if I can hob some new gears this weekend, would anyone else be intersted in me rebuilding thier oil pump if this works? let me know.
Michael
R Wyler
10-01-2006 19:08:35
 Re: advice on Case B plow in reply to RMO/MN, 09-30-2006 18:04:50
I bought some general purpose machinery shims for the tailwheel on one of mine. I would just put as many on there I possible without it turning hard and or binding up yet with as little end play as possible it can be tightened with that cup that is attached with a set screw on the inside of the axle also. Since these are not pulled all that fast in the field they its not all that crucial.
Jerry W
11-30-2005 19:05:53
 Re: VAC oil pump in reply to stout1, 11-30-2005 14:11:40
The oil pumps are different depending upon the year of the tractor. On the early ones the pump is built into the one main bearing cap.
Jerry
stout1
12-01-2005 02:17:52
 Re: VAC oil pump in reply to Jerry W, 11-30-2005 19:05:53
The pump that I am working on unbolts from the front main cap. If the gears are the same I don"t see why I wouldn"t be able to replace them, but I would have to look at it. I just finished sanding down the pump cover (where the pickup screws in) to remove the scratches and was now thinking about drilling a couple bypass ports to help keep the oil temp down. I just hope we have the right hob to make these gears.
Michael
stout1
11-30-2005 14:13:54
my e-mail is [email protected] I"m not sure on the cost yet to rebuild but if anyone is interested let me know. Thank You.
Michael
