380 L/L won't move...
GrampaT
11-30-2005 12:33:54
Hi All,
I have recently purchased a 380 L/L Construction King that runs but doesn't move. I have another post that asks for help in identifying the year as well. Seems the tool box and main serial # tag are together somewhere else. I have the numbers from the Engine stamp, ROPS tag and loader tag. The tractor, as I said runs and the 3 point seems to be ok (need to learn how to set all the knobs)however, at the higher RPM's it has a sputter. It will shift through the gears, albiet, a little stiff.
Any help will be appreciated.
Tom
JackNVA
12-05-2005 05:40:42
 Re: 380 L/L won't move... in reply to GrampaT, 11-30-2005 12:33:54
EBAY search on Case 380ck shows manuals for it.
The 380CK is related to the Case 1190, 1194, as well as the David Brown 3 cylinder models.
Jack
GrampaT
12-01-2005 06:00:10
 Re: 380 L/L won't move...additional comments in reply to GrampaT, 11-30-2005 12:33:54
I am thinking the clutch is the problem. Is there anything I can do/check before I begin to crack her open and take a look at the inards? Can the clutch be viewed without taking the trans cover off?
Again thanks for any input.
Tom
ray stark
12-02-2005 09:10:40
 Re: 380 L/L won't move...additional comments in reply to GrampaT, 12-01-2005 06:00:10
should have a red plastic cover on the bottom of tranny housing that can be removed via two bolts using a 7/16 wrench. don't know if you can see enough to tell for sure if it's the clutch. I don't think your unit will have a torque convert. most likely a 2 piece clutch like the 990 used is so your drive clutch can be shot and the live power and hydrualics will still work. i sent you an email seperatly detailing what we found to be the problem on a customers 380k
GrampaT
12-03-2005 04:07:24
 Re: 380 L/L won't move...additional comments in reply to ray stark, 12-02-2005 09:10:40
Thanks for the email and info Ray. That gives me a glimmer of hope. If the unit had a torque converter, it would have an additional lever/button or something obvious, I am assuming. That is why I am certain is does not. It has a 4 speed trans with 2 shift levers. One (on the left) for High/Low range with Forward and Reverse in each range. The right side is, 4 speeds only.
Again thanks
GrampaT
12-01-2005 19:04:05
I don't have an operators manual for this unit, but I don't believe it has a torque converter. Thank you for responding. What's scary about an industrial.
Camboted
12-01-2005 15:44:05
The guys on the forum are real shy about answering questions on industrial equipment. I posted two questions on a 480 LL and never got a bite. Our 480 has a torque converter, does yours? If so, that could be the problem. You'll proably have to split it to find out, but it might be worth a trip to the local Case IH dealer and talk with the shop foreman.
