VAC oil filter tube
Shaun Arms
11-30-2005 10:27:47
I was wondering if anybody could tell me where I can find that little tube thats inside the oil filter. Thanks in advance.
Shaun
Joe (Wa)
11-30-2005 16:12:20
 Re: VAC oil filter tube in reply to Shaun Arms , 11-30-2005 10:27:47
The tube is part of the original housing, does not have a separate part number.
Make one up out of 1/4" soft drawn tubing about 4 inches long. Solder one end closed, sand down the other end for interference fit in the base socket. Measure down from the soldered end about 3/8" and using a 1/16" or 3/32" drill straight through tube for oil outlet holes.
Press the tube into the base, screw a clear mason jar on the base, start the engine, check oil spray from the holes and that the tube is secure in the base socket.
Joe
