model c valve train
M. in sask
11-30-2005 06:57:34
I have a 1930 model C Can anyone tell me how the valve train gets oil ?There apears to be no passages through the head and when its runnung dosent have any splash Thanks Merv
Brian in Ohio
11-30-2005 10:46:54
 Re: model c valve train in reply to M. in sask, 11-30-2005 06:57:34
The valve train has to be oiled manually. When the tractor was being used full time, you were supposed to oil them everyday. If it's just a play toy, then I'd oil them once per show. Someone had suggested once to using STP oil treatment. It's sticky enough that you can put in on the valves before you leave for the show, and will still be there when you arrive.
M. in sask
11-30-2005 15:44:11
 Re: model c valve train in reply to Brian in Ohio, 11-30-2005 10:46:54
Thanks Brian I had no idea they were manualy lubed funny the didnt have ports on tappet cover so you didnt have to remove it. Thanks again Merv
