Hydralic oil (430 Case)
Dave F.
11-29-2005 11:42:29
What would be a good suitiable hydralic oil for my 430 Case It has just the regular transmission, not the Caseamatic, also looking for top shift cover for the triple range if anybody has one Thanks Dave F.
Dennis/Ohio
12-04-2005 01:49:13
 Re: Hydralic oil (430 Case) in reply to Dave F., 11-29-2005 11:42:29
The Case hydraulic oil is muli-viscosity. Like a 5-20w and great rust inhibitors. A knowlegable lubricant distributor will probably tell you the same. Don't forget the filter?
Best, Dennis.....
wayne woodrum
11-29-2005 15:25:06
The rear end and the 4speed trans.use 90wt gear oil, you can check oil level under the seat.
Roger (Mi)
11-29-2005 13:26:43
 Re: Hydraulic/transmission oil TCH in reply to Dave F., 11-29-2005 11:42:29
Because the oil put into the torque tube for hydraulics needs to lubricate transmission gears too, TCH (Torque Converter Hydraulic) is the recommended oil or find an oil that is an equivalent.
Dave F.
11-29-2005 14:02:32
 Re: Hydraulic/transmission oil TCH in reply to Roger (Mi), 11-29-2005 13:26:43
Roger, My 430 has a seperate plug/dipstick for the transmission the oil in there appears to be heavier (thicker) than hydralic oil. where I check the hydralic oil seperate plug/dipstick the fluid level is low not on the mark on the little dipstick. would it still be ok to use the hydralic oil that you metioned ? not owning this tractor for very long I am not quite famillar with it. Thanks again Dave F.
Roger (Mi)
11-30-2005 05:26:38
 Re: Hydraulic/transmission oil TCH in reply to Dave F., 11-29-2005 14:02:32
Wayne is right. There are TWO different oils used in your tractor (430). The 90W gear lube is used in the rear end. There is a long dip stick plug/rod located on the left near the driver's seat for checking that oil. The other is on the left side (pipe plug) near the hand clutch. It has a dip stick on that plug too for checking the TCH hydraulic oil level. Add TCH hydraulic oil through the plug located on the cover that is in FRONT of the gear shift cover. The 430 is a great tractor.
