given a tractor
herkpilot
11-29-2005 08:19:29
I'm being basically given a tractor and a bunch of implements. Not sure what it is but it's either a Case or International gasoline powered. Maybe 65hp. It's been sitting for almost 8 years but ran well prior to that as long as they kept filling the radiator. No water in the oil.
Other than checking all the fluids, doing a compression check and checking the valves are free, anyone have any ideas what I can do to minimize any damage before I fire this thing off? Ounce of prevention's worth a pound of cure.
Thanks
old
11-29-2005 15:05:37
 Re: given a tractor in reply to herkpilot, 11-29-2005 08:19:29
I'd fill the cylinders with tranny fluid and let it sit a day or 2, Also pour some down the exhaust, that will getto the valve thats open on the exhaust side of it. Put the plugs back in, then after that day or 2 pull all the plugs and spin it over to clear the cylinder of the tranny fluid. Doing that will help unstuck the rings/pistons and also help the valves.
herkpilot
11-29-2005 16:37:21
 Re: given a tractor in reply to old, 11-29-2005 15:05:37
Thanks a bunch! That sounds like a real good idea
old
11-29-2005 17:13:59
 Re: given a tractor in reply to herkpilot, 11-29-2005 16:37:21
I've used the tranny fluid like that in a number of tractors and so far all of them have run well after that. I also use that on engines with low compression and it also helps them.
wayne2
11-29-2005 13:25:34
Could squirt a little oil down cyls.! Roll over till pressure up!
