horizontal vs. vertical oil filters
INCase
11-29-2005 07:49:57
Is the horizontal oil filter setup from a 30 series (730 for example) interchangable with the vertical style used on the 700/800? thanks.
RCGREY
11-30-2005 10:12:02
 Re: horizontal vs. vertical oil filters in reply to INCase, 11-29-2005 07:49:57
there is a check valve in filter base that only allows oil to flow through filter one way. If you switch filter housings the check valve blocks oil from going through filter to main oil gally to main bearings cam etc. needless to say life off engine is severly shortened.hope this helps JIM
RCGREY
11-29-2005 15:12:28
Filter bases are interchangable but ports are reversed and oil flow is blocked. we learned the hard way Jim
INCase
11-29-2005 15:43:21
 Re: horizontal vs. vertical oil filters in reply to RCGREY, 11-29-2005 15:12:28
is the oil flow blocked at the engine block or in the filter? I"d much rather have the horiz. as the vertical is in the way of everything. THANKS!
