case 420 clutch
Tom Millard
11-28-2005 13:45:00
My cousin has a 420 case with backhoe and loader and when he redid the bearings in the engine fluid drained out of the bell housing. He replaced it and when he uses the loader once u get the weight in the bucket the tractor won't move. Is there something we oare overlooking????? ?? Any help would be apprecicated greatly..... Thanks, Tom
Phil Munson NY
11-28-2005 19:51:13
 Re: case 420 clutch in reply to Tom Millard, 11-28-2005 13:45:00
My case 420 TLB has a reverser and the case o matic torque converter. There is a lock out on mine that you can shift in to, for gear drive, once you are going. Try using a lower gear to see if it helps. If it does, then use the case o matic lock out once you are in motion. Hope htis helps, best, Yeoman
