Case 400 Diesel
walterinbr
11-27-2005 18:51:13
There is an oil level plug on the left side of the tractor about 3 inches behind the clutch rod. When I take the plug out oil drains out of it . What is this for and where do you add oil for this? Type of oil? I don't think this is the transmisson and rear end oil. Also , does anybody know what type of hydraulic loader would fit without too much modification? Thanks.
Dale In Tx
11-28-2005 17:25:09
 Re: Case 400 Diesel in reply to walterinbr, 11-27-2005 18:51:13
Walter That is the drain for belt pulley housing it is oil from the transmission it is feed up there by the gears Just holds about a cup full,only needs to be drained when changing oil in rear end. Later Dale In Tx.
