What to pay for an older Case 580C backhoe?
Randy Howard
11-27-2005 13:20:32
Hi all,
I have an opportunity to buy a well used Case 580C. It has an enclosed cab, runs well, uses a quart of engine oil every 16 hours, and has good tires. The hour meter stopped working at 2,800 hours so actual hours on the machine is unknown. It also has numerous leaks from weaping cylinders and the hoe has loose bushings everywhere. Engine runs great and the the transmission shifts fine. Cosmetically it is fair to good. So what should I offer for this beauty?
Also, my property is more mountainous than level. Will this machine work on an incline okay? The owner says the brakes are poor. Is this a common problem with the 580C or is something wrong here?
Thanks!
Randy
caae poor in pa
11-30-2005 16:53:23
 Re: What to pay for an older Case 580C backhoe? in reply to Randy Howard, 11-27-2005 13:20:32
i just bought a 580ck with bald tires on the back for 3500.00. runs good doesnt leak bad...bushings aint shot..it has one of them fancy diesel engines to..never thought id own one.but for 3500.00 what the heck....in north central peensylvania
John Gleaves
11-28-2005 11:54:15
I purchased a early '70's model 580 CK backhoe/loader around 50 horsepower. Very strong but I would be scared to death to take it on a slope. Mine is 2wd and can get stuck fairly easily. I paid $6,000 for it this summer. Everything works well on it, although I have become pretty good friends with my local hose & gasket shop. If you are truly going down some slopes I would be very hesitant unless you just happen to have a bulldozer handu to pull it out. Good luck!
old
11-27-2005 16:38:39
A friend traded a Ford 3000 for a 580 B a couple years ago. He put another $2000 in it in clutch and brake and a few other parts. I'd guess $5000-10,000 for one depnding on sheet metal, tires and how it works or doesn't, also leaks in the hyds.
wayne2
11-27-2005 14:27:16
Mountainous, just what is it you want to do? drainfields,dig stumps, If you have mountain goats round I'd be thinking more long lines of snow gromer and develop a ski resort!! LOL W
JimWilliamson
11-27-2005 13:31:09
Randy, I don't know what the old580 is worth but the brakes do wear down. They are easy to fix. They are shoes and disc combination. As the shoes start to grab the inner part starts to cause balls to go up a ramp forcing the disc part against the stationary wall of the drum. If you are mechanical at all you can figure it out and do it yourself. You can buy the shoes and rivet them on or you can buy the assembly.Not too costly JW
