Rebuilding My LA Engine
Gene Dotson
11-26-2005 14:43:15
I am planning to rebuild the engine in my 1948 LA. Would like to use M&W 4 7/8 sleeves with flattop pistons and a 6386a head. Has anyone used this combination on gasoline and how did it work?. What was the horsepower? What is the compression ratio? I am hoping to get 80 horsepower from it and run on regular gasoline. The tractor is used mainly for running sawmills and threshing machines at shows and maybe give the IH W9's some competition at our fun pulls. Thanks in advance for any information... Gene
Ralph NH
11-29-2005 11:40:15
 Re: Rebuilding My LA Engine in reply to Gene Dotson, 11-26-2005 14:43:15
Gene, thanks for the reply. Fly that Maule to NH sometime. My strip is on the NY sectional. NH49.Bradley Field. 1700' x 30' of hayfield here in the mountains. I'll show you around the farm. Good luck with the LA. My '49 is in about fifty pieces waiting for somebody (me) to paint it. Take care.
Walt Davies
11-28-2005 13:54:52
Gene I put an LP head on mine and had to get the LP piston because my old ones came about 1/16 to 1/18 above the cylnders the LP pistons were cut to fit the head I got quite a jump in HP on mine. My trouble now is keeping that dang Bosche Mag in time. Had to get a light and mark the front pulley and go from there because the marks on the flywheel don't mate up to the bosche mag.
If you add the larger bore you should increase compression but it would be cheaper just to shave off the head. Another friend on herer Roy siad his pistons didnot reach the top of the cylinder I wonder what the differance is.
Walt Davies
Gene Dotson
11-28-2005 17:01:05
 Re: Rebuilding My LA Engine in reply to Walt Davies, 11-28-2005 13:54:52
Walt; I want to make this a one time deal and get as much as I can without spending a lt of money. Have a line on the sleeves and pistons plus the LP head that was used on a LP engine, so I know they will physically work. Haven't torn the tractor down yet, but it is stamped for the high compression pistons. Early tractors were delivered with the low compression multi-fuel pistons. The LP conversion kits were supplied two different ways. One was to use M&W high dome pistons with the gasoline head and the other conversion used the flat top pistons and the 6386A head. M&W made a high dome piston for the gasoline head that worked well with the Gasoline head, but not the LP head. This was a 4 3/4" bore. This may be what you had... Gene
walt Davies
11-28-2005 18:04:47
 Re: Rebuilding My LA Engine in reply to Gene Dotson, 11-28-2005 17:01:05
Gene, My pistons are flat on top and stick above the cylinders into the head father than the head gasket will except them so I had to get the LP pistons to clear the LP head as it has a differant type of reccess in it. I have learned though that you can take the other heads down and have them machined to fit. Remember there are 2 left and 2 right pistons. they don't make it easy on us do they. I wonder how many differant kinds of pistons there are for this engine.
I would like to bring mine out to the 4 7/8 then stroke it but that won't happen until I get my land sold.
I would also like to get another case Mag and see if that helps any. I have one but the advance is frozen and I have tried everything to no avail.
Walt Davies
Ralph NH
11-28-2005 05:40:01
Gene,
Sorry you got no advice on your LA. I'm of no help either, just wondered if you still have your Maule. Also I'm amazed that you may get 80 hp with only another quarter inch of piston in your LA. I run a Lane sawmill with a '51 LA power unit but it has the original four and five-eighths pistons I think. Around 50hp. I still have my tri-pacer but don't fly it enough. Take care and good luck.
Gene Dotson
11-28-2005 05:59:03
 Re: Rebuilding My LA Engine in reply to Ralph NH, 11-28-2005 05:40:01
Nice to hear from you Ralph.
Yes, I still have the Maule. Like you, I don't fly enough. Too windy today.
The LA engine benefits a lot by increasing the compression. The stock late model engine with the high compression pistons develop about 58 horsepower and with a compression ratio of about 6.0 to 1. With the extra 1/4 inch of bore and an LP head with about 8 to 1. My tractor dyno'ed at 65 horsepower about 5 years ago, but is getting tired now... Gene
