700 lbs. Rear wheel weights
Specter
11-26-2005 14:40:16
third party image
I have a question for all of you here. What all do these wheel weights fit? They weigh about 700 lbs. each, and came off of an 830 Wheatland. Part # on them reads 5744A.
Specter in Alberta
57 caser
11-26-2005 14:49:29
 Re: 700 lbs. Rear wheel weights in reply to Specter, 11-26-2005 14:40:16
Those weights fit on the outside of the wheels they should center on a shoulder on the wheel. I replaced the pair on my 600 with 5 sets of 150 lb weights. Some of the wheatland models also had a set of weights inside the wheels but they are bigger in diameter and the center is big enough to fit around the axle housing.
Case Lady
11-26-2005 14:48:18
I may be mistaken, but they look real close to the ones we took off of a 1949 Case LA.
casemand-d
11-28-2005 12:01:56
 Re: 700 lbs. Rear wheel weights in reply to Case Lady, 11-26-2005 14:48:18
weight were also used on the LA's
caseman-d
