830 LP starter solenoid
awhitaker
11-26-2005 06:36:25
I guess my solenoid is out on my 1964 830 LP. It'll start if I arc over on the bolts, but that scares me being in front of the rear tire doing it. Though it won't start in gear it still scares me. Where do I get a replacement solenoid? Should I try to get this one rebuilt?
INCase
11-28-2005 08:44:22
 Re: 830 LP starter solenoid in reply to awhitaker, 11-26-2005 06:36:25
I was able to get a new one from my local NAPA. THat is a pretty common part used on a lot of different starters. If I have a chance I'll get the Part number from it.
GeoMo
11-28-2005 05:03:40
Which bolts are you jumping? My 830D will run the starter by jumping the large lugs but will not engage and turn the motor. If you are jumping the small int. terminal to hot lead the problem is in the switch circuit.
CK RICHARD
11-26-2005 15:12:09
some times you can take them apart and clean the contacts , I have done it 2 time on my 1030.
Lamont
11-26-2005 08:53:20
BE CAREFUL!!! I think it WILL start in gear if you jump it across the posts.
1030 Brian
11-26-2005 14:35:42
 Re: 830 LP starter solenoid in reply to Lamont, 11-26-2005 08:53:20
Hi, try your local NAPA they may be able to help
