carburetor for CO
toomanycases
11-24-2005 22:13:46
Need info! What carburetor goes on a CO #C311741. I just got one & carb is missing. Anyone know where I can get one, also parts & service manual? Anything special I need to know about the old CO. Just got it off the trailer & I can see a lot of work, Engine has one cylinder rusted up, I can turn it about 1/2 turn with the crank & then have to roll it backward in gear. Any suggestions? Oh well, it is almost as old as I am, but with a fresh paint job & little work, it look better than I do. Thanks, Chuck
toomanycases
11-25-2005 20:28:28
 Re: carburetor for CO in reply to toomanycases, 11-24-2005 22:13:46
Thanks guys, appeciate the information and comments. I was hoping to find a orignal type carb for it. At least now I know what type to look for. I have a couple of D carbs & will use as a last resort to get it running. Thanks again, Chuck
L.C.Grey
11-25-2005 05:28:06
Model C's from '29 thru '34 used the Kingston L-3
(1.25") carburetor before being changed to the Zenith TXOP for the beginning of the '35 models.
The L's also used the L-3s but were listed as a 1.50". I'm assuming the measurement is the venturi size.
The Kingstons are big ol chumks of brass and have a strange design that have what can be described best as having a "toilet flapper" inside them. I have never been able to get my '29 L to run as good as I'd like with the Kingston. If you adjust it to where it isn't too lean on the high end it black smokes like a diesel and loads up at idle.
Brian in Ohio
11-25-2005 04:37:09
Ted is right. A CO is basically a model C with some added features for use in an orchard. If push comes to shove, you can use engine parts from a DC. (Including the carb.)
Camboted
11-25-2005 04:30:22
Chuck,
That's like a 1933 right? Sure whish I had something to help you with after all you have done for me! I would think it would be the same as that on a C right? If so, put a post out to "Wilson" he has some C things and might be able to help.
