Case 580CK transmission noise
firemanjohn
11-24-2005 17:50:38
I am just breaking in my fixed up 580CK after an engine rebuild. I took the torque tube out while I was in there and just cleaned it out and such. When I run it now there is an awful lot of noise of the whining type which I assume to be air in the lines. I think so because it is a little slow on taking off too. It is full of oil and the fittings are all tight. Could it be air and where would it be coming from? Thank you
Steven K
11-25-2005 18:38:29
 Re: Case 580CK transmission noise in reply to firemanjohn, 11-24-2005 17:50:38
The transmission has a pick up tube mounted to the bottom of the cover plate below the transmission control valve. It could be drawing air there. Are you checking the oil in front of the four speed shifter? What kind of oil are you using? Did you replace the filter between the radiator and the grill? Is the oil foaming up?
firemanjohn
11-26-2005 17:08:00
 Re: Case 580CK transmission noise in reply to Steven K, 11-25-2005 18:38:29
I did check the oil in front of the four speed shifter. I even went the extra mile and am using Case Hy Trans. Brand new filter and O ring, with no leaks. Haven"t really used it much, just a couple trips around the yard, but it doesn"t seem to be foamy. I am stumped
Steven K
11-27-2005 10:28:59
 Re: Case 580CK transmission noise in reply to firemanjohn, 11-26-2005 17:08:00
Does the transmission gauge on the dash work? What does it say and is it steady?
